Dears:
Could you kindly help to check the latest version of Labview for debugging LMP91300?
And the other issue about the temperature is what will be happened if LMP91300 would be used under -55 degree?
Thanks!
Best regards
Luck Wu
Hi Luck,
Are you trying to debug the EVM or the GUI? Are you able to evaluate the EVM with the current GUI available on line?
Minimum operating temperature for this device is -40 C, the datasheet does not guarantee any electrical specs below this temperature. When you say used do you mean operate at -55 C or below?
Varn.
