Good evening,
we are developing a new instrument with two LDC1614 chip onboard.
My question is about the bit nr. 12 of each conversion result MSB register, the CHn_ERR_AE.
I don't understand well the correlation between CHn_ERR_AE and AH_ERR2OUT and AL_ERR_2OUT.
Is CHn_ERR_AE a general (both high/low) amplitude error?
To activate CHn_ERR_AE I need to set both AH_ERR2OUT and AL_ERR_2OUT, or only one is enough?
The situation is instead clearer for the Under/Over range and watchdog errors where I have direct correlation between UR_ERR2OUT and CHn_ERR_UR, OR_ERR2OUT and CHn_ERR_OR and so on.
Thank you in advance for the cooperation.
Best regards
Christian.
