I want to know if there is a possibility to read the data being saved, to DataOutput_XWR14xx.bin file from vitalSignsDemo_GUI program?
Thanks in advance,
Shai
Thanks in advance,
Shai
The truth is not so, the client could not decrypt and open the saved data to showcase them on plots to analyzing results, please find the attached file (please rename the file to .BIN).
Can you please try to elaborate more how it can be done and just wanted to know if it possible to get the source code of the demo GUI as well?
This will be highly appreciated , Thanks
Shai
Hello Shai,
It looks like there was a mistake in the table I posted earlier that did not include the necessary reserved bytes. Can you try with this structure instead?
Vital Signs Demo Packet Structure.pdf
Adrian
Hello Shai,
Sorry for the delayed response, I have been out of the office for the past two weeks. Regarding the <range_depth> <range_width> arguments, these arguments are not used in the code and should not need to be set. As you can see below, the defined function seen in the first line of the vitalSigns_demo_gui.m file does not contain the range depth or width arguments.
function [] = vitalSigns_demo_gui(comportSnum, comportCliNum, cliCfgFileName, loadCfg, app)
There is no way to run the .bin file using the Vital Signs GUI as it has not been designed to run previously saved data. What exactly are you trying to do by running the previously saved data through the GUI? If you want to somehow replay previously saved data this would require you to write your own code to do so.
Adrian
