Other Parts Discussed in Thread: SYSBIOS, MATHLIB
Hi
I am trying to build using CCS. Having set up the build environment. I am runnig "mmwave_sdk_setupenv.bat" and got
mmWave Build Environment Configured
Then when I run gmake all in CCS terminal under the directory "C:\ti\mmwave_sdk_01_00_00_05\packages\ti\drivers\adcbuf>" , I got the following error.
'[R4 Device/Type: awr16xx/xwr16xx] Building file: src/ADCBuf.c'
process_begin: CreateProcess(NULL, armcl -c -mv7R4 --code_state=32 --float_support=VFPv3D16 --abi=eabi -me --define=SUBSYS_MSS --define=SOC_XWR16XX --define=DOWNLOAD_FROM_CCS --define=DebugP_ASSERT_ENABLED -ic:/ti/m
mwave_sdk_01_00_00_05/packages -iC:/ti/ccsv7/tools/compiler/ti-cgt-arm_16.9.1.LTS/include -g -O3 -display_error_number --diag_warning=225 --diag_wrap=off --little_endian --preproc_with_compile --gen_func_subsections
-ppd=obj_xwr16xx/ADCBuf.d src/ADCBuf.c --output_file obj_xwr16xx/ADCBuf.oer4f, ...) failed.
make (e=2): The system cannot find the file specified.
gmake: *** [../../common/mmwave_sdk.mak:201: obj_xwr16xx/ADCBuf.oer4f] Error 2
antivirus is not working. I am using windows 10, latest CCS version updated. How I can I solve it.
Thanks in advance.
Burak
