Other Parts Discussed in Thread: IWR1443
The QSPI S25FL116K0XNFV010 is used in IWR1443Boost, this part is obsolete by the manufacture, what is the new replacement for this part? Could you provide the part number?
The following Flash ICs are supported according to TI:
Spansion S25FL256S
Spansion S25FL132K0XNFB010
Macronix MX25L3233F
Macronix MX25R1635FZNIH0 (Wide voltage part variant)
This information can be found in Chapter 5 of the linked document: http://software-dl.ti.com/ra-processors/esd/MMWAVE-DFP/latest/exports/mmwave_dfp_release_notes.pdf
I can confirm that Macronix MX25L3233F works perfectly with the IWR1443BOOST.
Kind regards,
Koos
Hi Feng,
I guess that one should work. Note that the part number is S25FL256SAGNFI003, with a capital i.
You could use this tool to see if there is a similar IC with better availability. The differences are mainly automotive qualification and temperature range.
However, Macronix MX25L3233F seems to be the only IC that has some reasonable availability, and is way cheaper.
Kind regards,
Koos
