Part Number: OPT8241-CDK-EVM
The device connects to Voxel Viewer but I cannot get an image to appear. It was working perfectly fine, but an hour later refused to work. I tried a firmware update and that did not help.
Below is a copy of the errors/warnings
Errors/Warnings
Voxel Viewer v0.9.10
Texas Instruments Inc.
INFO: ParameterDMLParser: Found register map with name 'OPT9221' (vPG1P0)
INFO: MainConfigurationFile: Reading from local copy of hardware configuration data
INFO: Data2DCodec: Original number of 8-bit offsets = 1005
INFO: Data2DCodec: Number of invalid pixels in original data = 0
INFO: Data2DCodec: Current number of 8-bit offsets = 1005
ERROR: DepthCamera: Could not set the camera profile to '79'
ERROR: DepthCamera:Could not get value for parameter TintinCDKCamera(0::0451:9105::10977221099732).vco_freq1
ERROR: DepthCamera: Failed to update value for parameter 'mod_freq1'
ERROR: DepthCamera:Could not get value for parameter TintinCDKCamera(0::0451:9105::10977221099732).vco_freq2
ERROR: DepthCamera: Failed to update value for parameter 'mod_freq2'
ERROR: DepthCamera: Failed to update value for parameter 'sysclk_in_freq'
ERROR: DepthCamera: Failed to update value for parameter 'quad_cnt_max'
ERROR: DepthCamera: Failed to update value for parameter 'vco_freq2'
ERROR: DepthCamera: Failed to update value for parameter 'vco_freq1'
ERROR: CameraSystem: Could not refresh parameters for TintinCDKCamera(0::0451:9105::10977221099732).
ERROR: DepthCamera:Could not get value for parameter TintinCDKCamera(0::0451:9105::10977221099732).vco_freq1Traceback (most recent call last):
File "D:\voxelviewerbitbucket\voxelviewer-devel\build\VoxelViewer\out00-PYZ.pyz\PyVoxelViewer.docks.FrequentlyUsedParametersDockWidget", line 93, in updateView
File "D:\voxelviewerbitbucket\voxelviewer-devel\build\VoxelViewer\out00-PYZ.pyz\PyVoxelViewer.docks.FrequentlyUsedParametersDockWidget", line 46, in showParam
File "D:\voxelviewerbitbucket\voxelviewer-devel\build\VoxelViewer\out00-PYZ.pyz\PyVoxelViewer.views.ParameterHandlerROI", line 127, in __init__
File "D:\voxelviewerbitbucket\voxelviewer-devel\build\VoxelViewer\out00-PYZ.pyz\PyVoxelViewer.views.ParameterHandlerROI", line 259, in init
File "D:\voxelviewerbitbucket\voxelviewer-devel\build\VoxelViewer\out00-PYZ.pyz\PyVoxelViewer.views.XYSpinBox", line 35, in setRange
OverflowError
ERROR: ToFCameraBase: Could not get current frame rate
INFO: ToFCameraBase: Starting with 352x352@0fps
ERROR: TintinCDKCamera: Could not get current frame rate
INFO: CameraSystem: DepthCamera for 0::0451:9105::10977221099732 was already created. Returning it.
OverflowError
