We are identifying sensors for measuring the Pressure imposed on a Metal body
Kiran. A.
Kiran. A.
Good morning Kiran and thank you for your query on the E2E forums,
I personally deal with magnetic current sensing products, so I wont be able to fully assist you with this query.
I can however refer to some of our inductive sensing products. I believe the LDC1314 is a good starting point. The way this device works is my measuring the deflection of a metal surface immediately above it, which translates to the pressure applied.
I will assign your post to my colleague Ben, in the meanwhile, should your query be urgent, please feel free to open a new thread selecting the device above so that the post is assigned to the correct group.
If you are looking at detecting the pressure applied to a metal surface then I would direct you to the following collateral:
TI Designs:
Application notes:
Videos:
I would also check out the rest of our application notes if you have further interest: http://www.ti.com/lsds/ti/sensing-products/inductive-sensing/inductive-sensing-technical-documents.page?familyId=3244&docCategoryId=1
Luke LaPointe
