Sir
Please suggest a temperature sensor for using in a micro controller based project for measuring temperature and humidity. in a room. The sensor can be either a single component or individual component's.
Thanking you
Prasanth JTO
BSNL
Sir
Thanking you
Prasanth JTO
BSNL
Hi Prasanth,
Thank you for your inquiries. In order for us to suggest a temperature sensor, do you know what is the temperature accuracy? What is the temperature and power supply range?
Aaron
Sir
I want to develop a product for measuring room temperature and humidity. Room temperature will be within -10C to 60C, but I want to use this temp sensor as common sensor for more application. So I want a temp sensor with range b/w -30C to +150C. And accuracy should be two decimal points. and power supply up to 5V.
Prasanth K N
Hi Prasanth,
We meet most of your requirements; unfortunately we are unable to meet the accuracy specification of two decimal points (for example 0.09°C). We do not have anything that can meet that yet. I am wondering if we can have a conference call to find out what kind of application. We may able to assist you. Please let me know.
Thank you. I am forwarding to hearing from you.
Aaron
Sir
My project is for measuring room temperature in a work space. I need a temperature sensor atleast an accuracy of one decimal point at a temp range of -40 to +150C. Please suggest a good sensor that can be useful for developing multiple applications
Prasanth
Hi Prasanth,
The LM57 analog temperature sensor would be the best choice for your application. Many microcontrollers have built-in ADCs that you can use to monitor the output voltage of the LM57. Please read through the LM57 datasheet, let me know if you have any question.
Aaron
