My customer uses the TMP007 and has a question.
He wants to know the temperature of a object after power on, ASAP.
How many seconds does it take it output a temperature data after power on?
Naoki Aoyama
Naoki Aoyama
Hi Naoki,
We will get back to you on this tomorrow.
Mayrim
Hi Naoki,
If the customer is powering the device off then powering the device back on, the TMP007 will initate a power-on-reset each time the power is re-applied. This will return the TMP007 to its defaut register settings. On default the TMP007 will power up in a continuous conversion mode with the conversion rate set for 1.01 s total conversion time. Therefore it will take just over 1 s before the first conversion is completed. As an alternative the customer can use the non-volatile memory to change the configuration register settings. iI for example they would like to reduce the conversion time to as low as 260 ms.
