I am trying to use TI infrared thermopile sensor ‘tmp006’.
While tuning some of the parameters, it’s noticed that I'm not able to change CR (Conversion Rate).
When tried to write a value to CR, i2c_smbus_write_word_data() is returning 0, but the content of CR is still default value.[ https://www.kernel.org/doc/Documentation/i2c/dev-interface :
All these transactions return -1 on failure; you can read errno to see what happened. The 'write' transactions return 0 on success]
Tried on 2 units of tmp006 and the same result found.
what could be the issue here ?
