Can you please elaborate on the temperature sensing accuracy testing method used for verifying the temp sensing accuracy specification(<+/-0.75degC) for the LM35 part? Basically accuracy would be the difference between the actual/reference temperature and the temperature readout as per LM35 output right. How was the temperature forced over the device? Was a thermostream approach used (eg www.temptronic.com/.../ThermoStream_Overview.htm), or was a peltier based approach used(eg www.mechanical-devices.com/.../PageGen2.asp)? www.grantinstruments.com/.../1._high_temperature_oil_baths___circulators.pdf, us.flukecal.com/.../6330732073407380-comp-0)?
Anoop
