According to SBOU142 (TMP007 calibration guide) which math algorithm is applied to TMP006 as well, at page 24 is stated: "As with all thermopiles, as the difference in temperature between the object and the sensor increases, so will the error."
Can someone from the TI engineering team to explain the statement above?
At the first glance this seems not correct. For the same ADC resolution used in the TMP006, a higher difference between the object and die temperature will increase the voltage read by the ADC. My measurements indicate around 5x-15x increase in the voltage for 16 different TMP006 thermopiles. Assuming the sensor noise is not affected by the Tobj-Tdie value, as higher the voltage value, as lower the error will be.
thank you,
