Hi all.
The new datasheet of TMP275 is issued because of PCN,
so I checked new detasheet and old data shteet.
About new datasheet,
Supply bypass capacitor's value is described 0.1uF or 0.01.
Which value is correct?
Sho Ogane
Hi all.
Sho Ogane
Hi Ren san
Thank you for the answer.
Two recommended values of supply bypass capacitors are described on the datasheet.
This datasheet is confusable.
So I would like you to unify the recomended value 0.1uF or 0.01uF.
Is it possible to update TMP275 datasheet?
Sho Ogane
