I recently purchased the SensorHub booster pack for the TivaTM4c123gh6pm board. Using the example programs the temperature sensor is pre-configured to print values to an output terminal on UART0. I am trying to change that output to UART1. There is a portion of code in the temperature_tmp006.c file that seems to be for the UART configuration. When I change the output pins, GPIO name and UART number... the changes seem to be accepted in the compiler, and compile with no errors , yet I am not getting anything out of the UART1 TX pin. could you please help me out with this. Attached is the file that I am trying to manipulate. the portion of the .c file that I tried to edit to work with the UART1 file is commented on the side, I reset the values back to their original states
// temperature_tmp006.c - Example to use of the SensorLib with the TMP006
// Copyright (c) 2013-2015 Texas Instruments Incorporated. All rights reserved.
// Software License Agreement
// Texas Instruments (TI) is supplying this software for use solely and
// exclusively on TI's microcontroller products. The software is owned by
// TI and/or its suppliers, and is protected under applicable copyright
// laws. You may not combine this software with "viral" open-source
// software in order to form a larger program.
// THIS SOFTWARE IS PROVIDED "AS IS" AND WITH ALL FAULTS.
// NO WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT
// NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. TI SHALL NOT, UNDER ANY
// CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR CONSEQUENTIAL
// DAMAGES, FOR ANY REASON WHATSOEVER.
// This is part of revision 2.1.2.111 of the EK-TM4C123GXL Firmware Package.
#include <stdint.h>
#include <stdbool.h>
#include "inc/hw_memmap.h"
#include "inc/hw_ints.h"
#include "driverlib/debug.h"
#include "driverlib/gpio.h"
#include "driverlib/interrupt.h"
#include "driverlib/pin_map.h"
#include "driverlib/rom.h"
#include "driverlib/sysctl.h"
#include "driverlib/uart.h"
#include "utils/uartstdio.h"
#include "sensorlib/hw_tmp006.h"
#include "sensorlib/i2cm_drv.h"
#include "sensorlib/tmp006.h"
#include "drivers/rgb.h"
//! \addtogroup example_list
//! <h1>Temperature Measurement with the TMP006 (temperature_tmp006)</h1>
//! This example demonstrates the basic use of the Sensor Library, TM4C123G
//! LaunchPad and the SensHub BoosterPack to obtain ambient and object
//! temperature measurements with the Texas Instruments TMP006 sensor.
//! Connect a serial terminal program to the LaunchPad's ICDI virtual serial
//! port at 115,200 baud. Use eight bits per byte, no parity and one stop bit.
//! The raw sensor measurements are printed to the terminal. The RGB LED
//! blinks at 1Hz once the initialization is complete and the example is
//! running.
// Define TMP006 I2C Address.
#define TMP006_I2C_ADDRESS 0x41
// Global instance structure for the I2C master driver.
tI2CMInstance g_sI2CInst;
// Global instance structure for the TMP006 sensor driver.
tTMP006 g_sTMP006Inst;
// Global new data flag to alert main that TMP006 data is ready.
volatile uint_fast8_t g_vui8DataFlag;
// Global new error flag to store the error condition if encountered.
volatile uint_fast8_t g_vui8ErrorFlag;
// Colors for the RGB LED.
uint32_t g_pui32Colors[3];
// Application function to capture ASSERT failures and other debug conditions.
#ifdef DEBUG
void
__error__(char *pcFilename, uint32_t ui32Line)
#endif
// TMP006 Sensor callback function. Called at the end of TMP006 sensor driver
// transactions. This is called from I2C interrupt context. Therefore, we just
// set a flag and let main do the bulk of the computations and display.
void
TMP006AppCallback(void *pvCallbackData, uint_fast8_t ui8Status)
// If the transaction succeeded set the data flag to indicate to
// application that this transaction is complete and data may be ready.
if(ui8Status == I2CM_STATUS_SUCCESS)
g_vui8DataFlag = 1;
// Store the most recent status in case it was an error condition
g_vui8ErrorFlag = ui8Status;
// TMP006 Application error handler.
void
TMP006AppErrorHandler(char *pcFilename, uint_fast32_t ui32Line)
// Set terminal color to red and print error status and locations
UARTprintf("\033[31;1m");
UARTprintf("Error: %d, File: %s, Line: %d\n"
"See I2C status definitions in utils\\i2cm_drv.h\n",
g_vui8ErrorFlag, pcFilename, ui32Line);
// Return terminal color to normal
UARTprintf("\033[0m");
// Set RGB Color to RED
g_pui32Colors[0] = 0xFFFF;
g_pui32Colors[1] = 0;
g_pui32Colors[2] = 0;
RGBColorSet(g_pui32Colors);
// Increase blink rate to get attention
RGBBlinkRateSet(10.0f);
// Go to sleep wait for interventions. A more robust application could
// attempt corrective actions here.
while(1)
ROM_SysCtlSleep();
// Called by the NVIC as a result of I2C3 Interrupt. I2C3 is the I2C connection
// to the TMP006.
void
TMP006I2CIntHandler(void)
// Pass through to the I2CM interrupt handler provided by sensor library.
// This is required to be at application level so that I2CMIntHandler can
// receive the instance structure pointer as an argument.
I2CMIntHandler(&g_sI2CInst);
// Called by the NVIC as a result of GPIO port E interrupt event. For this
// application GPIO port E pin 0 is the interrupt line for the TMP006
void
IntGPIOe(void)
uint32_t ui32Status;
ui32Status = GPIOIntStatus(GPIO_PORTE_BASE, true);
// Clear all the pin interrupts that are set
GPIOIntClear(GPIO_PORTE_BASE, ui32Status);
if(ui32Status & GPIO_PIN_0)
// This interrupt indicates a conversion is complete and ready to be
// fetched. So we start the process of getting the data.
TMP006DataRead(&g_sTMP006Inst, TMP006AppCallback, &g_sTMP006Inst);
// Configure the UART and its pins. This must be called before UARTprintf().
void
ConfigureUART(void)
// Enable the GPIO Peripheral used by the UART.
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
//changed A to B
// Enable UART0
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0);
//changed from 0 to 1
// Configure GPIO Pins for UART mode.
ROM_GPIOPinConfigure(GPIO_PA0_U0RX);
//changed from PA0 to PB0
ROM_GPIOPinConfigure(GPIO_PA1_U0TX);
//Changed from PA1 to PB1
ROM_GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1); //PortA to PortB , Pin 0 to pin 0, pin 1 to pin 1
// Use the internal 16MHz oscillator as the UART clock source.
UARTClockSourceSet(UART0_BASE, UART_CLOCK_PIOSC);
// Initialize the UART for console I/O.
UARTStdioConfig(0, 9600, 16000000);
// changed from 0 to 1
// Main 'C' Language entry point.
int
main(void)
float fAmbient, fObject;
int_fast32_t i32IntegerPart;
int_fast32_t i32FractionPart;
// Setup the system clock to run at 40 Mhz from PLL with crystal reference
ROM_SysCtlClockSet(SYSCTL_SYSDIV_5 | SYSCTL_USE_PLL | SYSCTL_XTAL_16MHZ |
SYSCTL_OSC_MAIN);
// Enable the peripherals used by this example.
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOE);
// Initialize the UART.
ConfigureUART();
// Print the welcome message to the terminal.
// UARTprintf("\033[2J\033[1;1HTMP006 Example\n");
// Setup the color of the RGB LED.
g_pui32Colors[RED] = 0;
g_pui32Colors[BLUE] = 0xFFFF;
g_pui32Colors[GREEN] = 0;
// Initialize the RGB Driver and start RGB blink operation.
RGBInit(0);
RGBIntensitySet(0.5f);
RGBEnable();
// The I2C3 peripheral must be enabled before use.
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_I2C3);
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD);
// Configure the pin muxing for I2C3 functions on port D0 and D1.
// This step is not necessary if your part does not support pin muxing.
ROM_GPIOPinConfigure(GPIO_PD0_I2C3SCL);
ROM_GPIOPinConfigure(GPIO_PD1_I2C3SDA);
// Select the I2C function for these pins. This function will also
// configure the GPIO pins pins for I2C operation, setting them to
// open-drain operation with weak pull-ups. Consult the data sheet
// to see which functions are allocated per pin.
GPIOPinTypeI2CSCL(GPIO_PORTD_BASE, GPIO_PIN_0);
ROM_GPIOPinTypeI2C(GPIO_PORTD_BASE, GPIO_PIN_1);
// Configure and Enable the GPIO interrupt. Used for DRDY from the TMP006
ROM_GPIOPinTypeGPIOInput(GPIO_PORTE_BASE, GPIO_PIN_0);
GPIOIntEnable(GPIO_PORTE_BASE, GPIO_PIN_0);
// changed E to C
ROM_GPIOIntTypeSet(GPIO_PORTE_BASE, GPIO_PIN_0, GPIO_FALLING_EDGE);
ROM_IntEnable(INT_GPIOE);
// Keep only some parts of the systems running while in sleep mode.
// GPIOE is for the TMP006 data ready interrupt.
// UART0 is the virtual serial port
// TIMER0, TIMER1 and WTIMER5 are used by the RGB driver
// I2C3 is the I2C interface to the TMP006
ROM_SysCtlPeripheralClockGating(true);
ROM_SysCtlPeripheralSleepEnable(SYSCTL_PERIPH_GPIOE);
//changed E to C
ROM_SysCtlPeripheralSleepEnable(SYSCTL_PERIPH_UART0);
//changed uart0 to uart4
ROM_SysCtlPeripheralSleepEnable(SYSCTL_PERIPH_TIMER0);
ROM_SysCtlPeripheralSleepEnable(SYSCTL_PERIPH_TIMER1);
ROM_SysCtlPeripheralSleepEnable(SYSCTL_PERIPH_I2C3);
ROM_SysCtlPeripheralSleepEnable(SYSCTL_PERIPH_WTIMER5);
// Enable interrupts to the processor.
ROM_IntMasterEnable();
// Initialize I2C3 peripheral.
I2CMInit(&g_sI2CInst, I2C3_BASE, INT_I2C3, 0xff, 0xff,
SysCtlClockGet());
// Initialize the TMP006
TMP006Init(&g_sTMP006Inst, &g_sI2CInst, TMP006_I2C_ADDRESS,
// Put the processor to sleep while we wait for the I2C driver to
// indicate that the transaction is complete.
while((g_vui8DataFlag == 0) && (g_vui8ErrorFlag == 0))
ROM_SysCtlSleep();
// If an error occurred call the error handler immediately.
if(g_vui8ErrorFlag)
TMP006AppErrorHandler(__FILE__, __LINE__);
// clear the data flag for next use.
g_vui8DataFlag = 0;
// Delay for 10 milliseconds for TMP006 reset to complete.
// Not explicitly required. Datasheet does not say how long a reset takes.
ROM_SysCtlDelay(ROM_SysCtlClockGet() / (100 * 3));
// Enable the DRDY pin indication that a conversion is in progress.
TMP006ReadModifyWrite(&g_sTMP006Inst, TMP006_O_CONFIG,
~TMP006_CONFIG_EN_DRDY_PIN_M,
TMP006_CONFIG_EN_DRDY_PIN, TMP006AppCallback,
&g_sTMP006Inst);
// Wait for the DRDY enable I2C transaction to complete.
ROM_SysCtlSleep();
if(g_vui8ErrorFlag)
g_vui8DataFlag = 0;
// Last thing before the loop start blinking to show we got this far and
// the tmp006 is setup and ready for auto measure
RGBBlinkRateSet(1.0f);
// Loop Forever
while(1)
// Put the processor to sleep while we wait for the TMP006 to
// signal that data is ready. Also continue to sleep while I2C
// transactions get the raw data from the TMP006
ROM_SysCtlSleep();
if(g_vui8ErrorFlag)
// Reset the flag
g_vui8DataFlag = 0;
// Get a local copy of the latest data in float format.
TMP006DataTemperatureGetFloat(&g_sTMP006Inst, &fAmbient, &fObject);
// Convert the floating point ambient temperature to an integer part
// and fraction part for easy printing.
i32IntegerPart = (int32_t)fAmbient;
i32FractionPart = (int32_t)(fAmbient * 100.0);
i32FractionPart = i32FractionPart - (i32IntegerPart * 100);
//// if(i32FractionPart < 0)
//// i32FractionPart *= -1;
UARTprintf("%3d%3d",i32IntegerPart, i32FractionPart);
