I am currently working with a TMP75 and in verifying operation, I am encountering a configuraiton problem.
Upon startup, the device reads correct 12 bit data even though I am not giving a configuration command. The data sheet says on startup the device should only give 9 bits of resolution.
When I try to configure the device for 9 bits, resolution stays at 12 bits.
I am not doing a General Call at the beginning of the transaction. Is this mandatory? If so, does the General Call follow the format of a 5 frame write command as outlined in the datasheet?
Thanks for the help,
-Jordan
