How to make the output pin TCRITx of LM95214 recover?
Other Parts Discussed in Thread: LM95214
  I`m using LM95214 in my board. when the temperature is above the limitation, the related TCRITx will change to low, then when
the temperature reback to the normal one(under the limitation), the TCRITx should be changed to high. however the situation I met isn`t like this. if  need the TCRITx reback to high when the temperature back under the limitation, what should I do? does it  be done automatically or need to do mannually? thanks a lot
