I added tmp006drv.c and .h to i2c_demo with a "getTemp" added to commands using the tmp006drv functions, linked with vfplib for floting point support on a cc3200LP and got the following results:
Command Usage
write <dev_addr> <wrlen> <<byte0> [<byte1> ... ]> <stop>
- Write data to the specified i2c device
read <dev_addr> <rdlen>
- Read data frpm the specified i2c device
writereg <dev_addr> <reg_offset> <wrlen> <<byte0> [<byte1> ... ]>
- Write data to the specified register of the i2c device
readreg <dev_addr> <reg_offset> <rdlen>
- Read data from the specified register of the i2c device
Parameters
dev_addr - slave address of the i2c device, a hex value preceeded by '0x'
reg_offset - register address in the i2c device, a hex value preceeded by '0x'
wrlen - number of bytes to be written, a decimal value
rdlen - number of bytes to be read, a decimal value
bytex - value of the data to be written, a hex value preceeded by '0x'
stop - number of stop bits, 0 or 1
cmd#getTemp
GetTemp = 74.501472
cmd#getTemp
GetTemp = 32.864563
cmd#getTemp
GetTemp = 33.981861
cmd#getTemp
GetTemp = 72.361816
cmd#getTemp
GetTemp = 78.808800
cmd#getTemp
GetTemp = 82.950294
cmd#getTemp
GetTemp = 77.524170
cmd#getTemp
GetTemp = 79.685715
cmd#getTemp
GetTemp = 77.442101
cmd#getTemp
GetTemp = 82.193268
cmd#getTemp
GetTemp = 22.307100
cmd#getTemp
GetTemp = -6.418549
cmd#
the low numbers were obtained when my finger was touching the sensor or very near it. Why would the values be so low? Shorting/altering data? I read datasheet and get that it reads an infrared radiation bandwidth, but I don't see how the skin would mess such up? Emissivity?
