Other Parts Discussed in Thread: TMP302, TMP303
Hi team,
My customer is using TMP411 and wants to know the THERM pin (pin 4) logic.
Test condition: -40 degree C, and TMP411 is used to enable the whole system. I want to double check the status of THERM pin at power on. is default setting for the THERM range 0~85C, or just below 85C?
customer found the system start up normally at -40C. could you please double confirm whether there's low temp limit at power up of the THERM pin?
thanks
Mike
