TMP302: TMP302
Part Number: TMP302
Hi, Team!
I need to install sensor TMP302 to D-pack diode width D-pack cooler.
How to install  sensor TMP302 correctly? I use SMD mount and sensor TMP302 in
 micropackage SOT563. How to provide termo connection? Maybe you have photo?
Best Regards, Andrey
  • Hi Andrey,
    Thanks for your interest on TMP302. Please see the figure 14 on the TMP302 Data sheet (Section 10. PCB Guideliness) where clearly shows the recommended scheme to connect a GND plane for a solid thermal coupling to the heat source.
    Thanks!
