Hi team,
We use TMP422 and the remote pin connect to the thermal sensor by a cable.
If we remove the thermal sensor, we still get +/-1C pulse from I2C remote temperature register. Is it a normal symptom?
In addition, when we use finger press on TMP422 top case, the local temp and remote temp (also disconnect thermal sensor), both temperature ramp up obviously. Is it a normal symptom?
Please kindly help
