Other Parts Discussed in Thread: TMP102, TMP108, TMP106, TMP112
Dear all,
one of my customer is using the TMP103 in an application very sensitive to the power consumption. In order to save power the designer remove the power supply to the TMP103 (High side P Mosfet) leaving the I2C pin (SDA, SCL) connected to the bus. In this condition due to ESD protection the device burns more current and at the next power up it does not communicate on I2C bus.
Could make sense to insert a P mosfet also in the SCL and SDA pin in order to completely disconnect the TMP103 from any voltage ?
I've attached the current solution and the proposal.
regards,
Domenico
