Hi, Team,
We have questions for TMP112.
-Could you teach us Power-up Reset grantee value? (For example, maximum voltage or time)
-Can we use default configuration after the Power-up Reset if we don't use ALART pin?
Satoshi Yone
Hi, Team,
Satoshi Yone
Hi, Ren,
We want to ask more detail.
-Could you teach me the attached ??V and ??ms spec?
-We don't need to write initial configuration if the ALERT pin is floating or connected to ground. Is my understanding correct?
The TMP112 Datasheet description requires a pullup resistor, so I would like to confirm the ALERT pin configuration.
Satoshi Yone
