The TDC1000-TDC7200 dev kit has a 200 ohm resistor on the transit line. I've already maxed out the gain, and I'd like to boost the signal even more. I can boost the signal by shorting out the resistor on the transmit line. Are there any negative effects I should look out for while reducing the value of the transmit resistor?
