The quesiton focuses the AFE5818, however is generally related to high-speed ADCs with LVDS outputs.
I keep noting in various articles that LVDS-type ADC does not support deterministic latency (hence may pose troubles to synchronize several of such devices)
However, AFE5818 as an example of such, there is known parameter as ADC latency (8.5 device clocks by default unless configured for low-latency mode allowing 4.5 clocks).
If this parameter is known ahead - why it is considered non-deterministic ? Lets say having 10 of such devices in the system that need to be synchronized to each other.
If the ADC latency is known ahead, the effort to achieve multi-device sync is just to properly layout the PCB with ADC Clock to be distributed in-phase to all and take care to route LVDS outputs allowing aligning of timing delays (length match + impedance). What is non-determinisic here ?
Would appreciate for clarification of the matter
Thanks, Alex
