Other Parts Discussed in Thread: TDC7200
I am trying to interface with the TDC7200 with a minimum amount of GPIOs. When I toggle the chip select pin (CSB) between commands, the TDC works fine. However, it seems that the TDC does not respond if the chip select (CSB) is held low at all times.
Is it required to toggle the chip select pins between commands?
