Other Parts Discussed in Thread: MSP430F5529, ENERGIA
I would like to know, how can I get the tof data from the TDC7210 to MSP430f5529 without gui connection. In this EVM firmware, how can I add modified function?
//****************************************************************************** // Demo Application01 for MSP430/TDC720x Interface Code Library v1.0 // Byte Read/ Byte Write TDC720x Registers // // MSP430F5529 // ----------------- // /|\| XIN|- // | | | // --|RST XOUT|- // | | // | P3.0/UCB0SIMO|--> SDI // | P3.1/UCB0SOMI|<-- SDO // | P3.2/UCB0CLK|--> CLK // | P2.6|--> CSB // | P2.4| // | | // | P1.2| // // Vishy Natarajan // Texas Instruments Inc. // March 2013 // Built with IAR Embedded Workbench Version: 5.5x //****************************************************************************** /* Copyright 2011-2012 Texas Instruments Incorporated. All rights reserved. IMPORTANT: Your use of this Software is limited to those specific rights granted under the terms of a software license agreement between the user who downloaded the software, his/her employer (which must be your employer) and Texas Instruments Incorporated (the "License"). You may not use this Software unless you agree to abide by the terms of the License. The License limits your use, and you acknowledge, that the Software may not be modified, copied or distributed unless embedded on a Texas Instruments microcontroller which is integrated into your product. Other than for the foregoing purpose, you may not use, reproduce, copy, prepare derivative works of, modify, distribute, perform, display or sell this Software and/or its documentation for any purpose. YOU FURTHER ACKNOWLEDGE AND AGREE THAT THE SOFTWARE AND DOCUMENTATION ARE PROVIDED 鄭S IS� WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED, INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY, TITLE, NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL TEXAS INSTRUMENTS OR ITS LICENSORS BE LIABLE OR OBLIGATED UNDER CONTRACT, NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER LEGAL EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES INCLUDING BUT NOT LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE OR CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST OF PROCUREMENT OF SUBSTITUTE GOODS, TECHNOLOGY, SERVICES, OR ANY CLAIMS BY THIRD PARTIES (INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS. Should you have any questions regarding your right to use this Software, contact Texas Instruments Incorporated at www.TI.com. *******************************************************************************/ #include <stdio.h> #include <stdint.h> #include "TI_TDC720x.h" #include "TI_MSP430.h" #include "TI_MSP430_hardware_board.h" #include "TI_MSP430_spi.h" #include "HAL_PMM.h" void Init_Clock (void); void InitMCU(void); // Test TDC720x Register Read/Write & Conversion uint32_t clk_count; uint8_t read_val[3], all_data[TDC720x_ALL_DATA_SIZE], byte_data; uint32_t tout = 0; uint8_t TDC720x_Parallel_Read = 1; //****************************************************************************** void main(void) { WDTCTL = WDTPW+WDTHOLD; // Stop WDT TI_TDC720x_GLED_PxOUT |= TI_TDC720x_GLED_PIN; // Set LED ON TI_TDC720x_GLED_PxDIR |= TI_TDC720x_GLED_PIN; // Set pin direction is output TI_TDC720x_RLED_PxOUT &= ~TI_TDC720x_RLED_PIN; // Set RLED OFF TI_TDC720x_RLED_PxDIR |= TI_TDC720x_RLED_PIN; // Set pin direction TI_TDC720x_OSCENABLE_PxOUT |= TI_TDC720x_OSCENABLE_PIN; // Set pin high: enable afe osc TI_TDC720x_OSCENABLE_PxDIR |= TI_TDC720x_OSCENABLE_PIN; // Set pin direction is output TI_TDC720x_ENABLE1_PxOUT |= TI_TDC720x_ENABLE1_PIN; // Enable device TI_TDC720x_ENABLE1_PxDIR |= TI_TDC720x_ENABLE1_PIN; // Set pin direction output #if 0 TI_TDC720x_FLAG_PxOUT |= TI_TDC720x_FLAG_PIN; // Flag Input Pull up enable TI_TDC720x_FLAG_PxREN |= TI_TDC720x_FLAG_PIN; // Flag Input Resistor enable TI_TDC720x_FLAG_PxDIR &= ~TI_TDC720x_FLAG_PIN; // Set pin direction input #endif // configure Port Pin to handle Interrupt Bar Output (INTB) from TDC720x TI_TDC720x_INTB_PxDIR &= ~TI_TDC720x_INTB1_PIN; // Set up port pin for INTB TI_TDC720x_INTB_PxOUT |= TI_TDC720x_INTB1_PIN; // INTB Input Pull up enable TI_TDC720x_INTB_PxREN |= TI_TDC720x_INTB1_PIN; // INTB Input Resistor enable TI_TDC720x_INTB_PxIES |= TI_TDC720x_INTB1_PIN; // Interrupt Edge Select TI_TDC720x_INTB_PxIFG &= ~TI_TDC720x_INTB1_PIN; // Clear Interrupt Flag // TI_TDC720x_INTB_PxIE |= TI_TDC720x_INTB1_PIN; // Enable Port interrupt // oscillator fail if LED keeps flashing after InitMCU InitMCU(); TI_TDC720x_SPISetup(); // Initilaize MSP430 SPI Block // Test TDC720x Register Read/Write & Conversion read_val[0] = TI_TDC720x_SPIByteReadReg(0x00, TDC720x_TDC2); read_val[1] = TI_TDC720x_SPIByteReadReg(0x01, TDC720x_TDC2); read_val[2] = TI_TDC720x_SPIByteReadReg(0x03, TDC720x_TDC2); TI_TDC720x_SPIByteWriteReg(0x01, 0x40, TDC720x_TDC2); read_val[0] = TI_TDC720x_SPIByteReadReg(0x00, TDC720x_TDC2); read_val[1] = TI_TDC720x_SPIByteReadReg(0x01, TDC720x_TDC2); read_val[2] = TI_TDC720x_SPIByteReadReg(0x03, TDC720x_TDC2); #if 0 // read config1 register byte_data = TI_TDC720x_SPIByteReadReg(TI_TDC720x_CONFIG1_REG, TDC720x_TDC1); // set mode 2 & start measurement bit byte_data |= 0x03; TI_TDC720x_SPIByteWriteReg(TI_TDC720x_CONFIG1_REG, byte_data, TDC720x_TDC1); //wait for INTB pin to go low tout = 0; while(TI_TDC720x_INTB_PxIN & TI_TDC720x_INTB1_PIN) { tout++; if (tout >= TIMEOUT_VALUE) break; } TI_TDC720x_SPIAllReadReg(all_data, TDC720x_TDC1); clk_count = TI_TDC720x_SPILongReadReg(0x11, TDC720x_TDC1); #endif // test if byte write/read values match if (read_val[1] == 0x40) { while (1) // no error: blink LED continuously { __delay_cycles(250000); __delay_cycles(250000); TI_TDC720x_GLED_PxOUT ^= TI_TDC720x_GLED_PIN; } } else { TI_TDC720x_GLED_PxOUT &= ~TI_TDC720x_GLED_PIN; // error: Set LED OFF } __bis_SR_register(LPM0_bits + GIE); // Enter LPM0, enable interrupts __no_operation(); // For debugger } //****************************************************************************** //****************************************************************************** /** * @brief Function Name: Init_Clock . * @brief Description : Initializes MSP430 clock module. * @param parameters : none * @return Value : none */ //****************************************************************************** void Init_Clock(void) { // UCSCTL3 = SELREF_2; // Set DCO FLL reference = REFO // UCSCTL4 |= SELA_2; // Set ACLK = REFO // Enable XT2 XIN/XOUT Pins P5SEL |= 0x0C; // Select XIN, XOUT on P5.3 and P5.2 UCSCTL6 &= ~XT2OFF; // Enable XT2 UCSCTL6 |= XT2DRIVE_3; P5SEL |= BIT4+BIT5; // Select XT1 UCSCTL6 &= ~(XT1OFF); // XT1 On UCSCTL6 |= XCAP_3; // Internal load cap UCSCTL3 = 0; // FLL Reference Clock = XT1 // Loop until XT1,XT2 & DCO stabilizes - In this case loop until XT1 and DCo settle do { UCSCTL7 &= ~(XT2OFFG + XT1LFOFFG + DCOFFG); // Clear XT2,XT1,DCO fault flags SFRIFG1 &= ~OFIFG; // Clear fault flags TI_TDC720x_RLED_PxOUT ^= TI_TDC720x_RLED_PIN; // Toggle LED __delay_cycles(250000); }while (SFRIFG1&OFIFG); // Test oscillator fault flag UCSCTL6 &= ~(XT1DRIVE_3); // Xtal is now stable, reduce drive strength UCSCTL4 |= SELA_0; // ACLK = LFTX1 (by default) __bis_SR_register(SCG0); // Disable the FLL control loop UCSCTL0 = 0x0000; // Set lowest possible DCOx, MODx UCSCTL1 = DCORSEL_7; // Select DCO range 50MHz operation UCSCTL2 = FLLD_0 + 747; // Set DCO Multiplier(762/498) for 25MHz/16MHz // (N + 1) * FLLRef = Fdco // (762 + 1) * 32768 = 25MHz // Set FLL Div = fDCOCLK/2 __bic_SR_register(SCG0); // Enable the FLL control loop // Worst-case settling time for the DCO when the DCO range bits have been // changed is n x 32 x 32 x f_MCLK / f_FLL_reference. See UCS chapter in 5xx // UG for optimization. // 32 x 32 x 25 MHz / 32,768 Hz ~ 780k MCLK cycles for DCO to settle __delay_cycles(782000); // Loop until XT1,XT2 & DCO stabilizes - In this case only DCO has to stabilize do { UCSCTL7 &= ~(XT2OFFG + XT1LFOFFG + DCOFFG); // Clear XT2,XT1,DCO fault flags SFRIFG1 &= ~OFIFG; // Clear fault flags TI_TDC720x_RLED_PxOUT ^= TI_TDC720x_RLED_PIN; // Toggle LED __delay_cycles(250000); }while (SFRIFG1&OFIFG); // Test oscillator fault flag UCSCTL4 = SELA__XT1CLK + SELS__DCOCLKDIV + SELM__DCOCLKDIV; // SMCLK=MCLK= // Loop until XT1,XT2 & DCO stabilizes - In this case only DCO has to stabilize do { UCSCTL7 &= ~(XT2OFFG + XT1LFOFFG + DCOFFG); // Clear XT2,XT1,DCO fault flags SFRIFG1 &= ~OFIFG; // Clear fault flags TI_TDC720x_RLED_PxOUT ^= TI_TDC720x_RLED_PIN; // Toggle LED __delay_cycles(250000); }while (SFRIFG1&OFIFG); // Test oscillator fault flag TI_TDC720x_RLED_PxOUT &= ~TI_TDC720x_RLED_PIN; // turn off red } //****************************************************************************** /** * @brief Local functions. */ /** * @brief Function Name: InitMCU. * @brief Description : Initializes the MSP430 peripherals and modules. * @param parameters : none * @return Value : none */ //****************************************************************************** void InitMCU(void) { __disable_interrupt(); // Disable global interrupts SetVCore(3); Init_Clock(); //Init clocks __enable_interrupt(); // enable global interrupts } //******************************************************************************
Thank you.
Ahmed Syed Fahin
