Other Parts Discussed in Thread: OPT8241
What are the signal paths tested by the PHY and MAC test withing the OPT9221. Does the MAC test generate input data that passes through the DDR2 RAM interface and then on to the output block? Does the PHY test just generate a ramp signal directly at the output block without testing any other internal paths?
We are having issues with intermittent noise and image quality and the MAC test ramp signal is showing the same image quality problems, so I would really like to know if the DDR2 is in the path of the MAC test.
What other issues could we have if the ramp image generated by the MAC test is speckled/noisy but the PHY test ramp pattern is OK.
Mike
