Hi
We are looking for ultra low power sensor to detect Aluminium plate for a battery operated application. Distance 2 cm to 10 cm.
Advice any suitable solution fromTI
K.B
Hi Krishnamoorthy,
For this application I'd recommend either the LDC1101 or the LDC161x. This is because 10cm is a large detection distance for inductive sensing, and these two devices are high resolution. You can compare these devices (and all of our other LDC devices) in the LDC Device Selection Guide.
For further reading, I recommend LDC Sensor Design and LDC Target Design, both of which contain critical information for designing inductive sensing systems.
Finally, all of our LDC devices have evaluation modules available, so I would recommend purchasing one to test if the device meets your application's requirements.
Hi Kristin Jones
Please find details of the application, Request you to review and advice suitable part for our applocation
Hi Krishnamoorthy,
My apologies for the confusion. I need to know what current draw is acceptable for your inductive sensing system. This is what I meant by current budget.
If you have space on your PCB for a 40mm coil and the LDC2114 current draw is acceptable to you, this is the device I would recommend using.
Hi
please note further details including battery current budget
Advice if we can proceed with the suggested solution
