Other Parts Discussed in Thread: UNIFLASH,
Hi Forum,
I have a new design based on the AWR1642BOOST REV A.
I have programmed the SDK 2.0 demo binary into the QSPI Flash using Uniflash. Then I remove the SOP jumper.
I cycle power, then run the visualizer 2.0.0, and click 'SEND CONFIG TO MMWAVE DEVICE" with the default values shown. I am just trying to get RADAR activity of any kind.
I see the power supply periodically increase by about 0.5 Watts, and I can start and stop the sensor, no problem.
But there is no data - no plots, no heat map, and 'log data from PC' has 0 bytes.
The console below is after I have stopped and started the sensor, otherwise you wouldn't see the Init Calibration Status, I don't think
Can anyone suggest what might be keeping the BSS from running?
