  • TI Thinks Resolved
AWR1642: AWR1642
Prodigy 220 points
Part Number: AWR1642
About the layout question:
The ground vias around the RF traces of the AWR1642 its drill diameter is 5.9mil on TI design guide, if we want to change it to 5mil,
will the RF performance be affected ?
michael Su
  • Hi Michael,
    This thread is assigned to concern expert, you will hear back soon.
    Jitendra
  • In reply to Jitendra Gupta:
    Hello Michael,
    A change from 5.9 mils to 5mils via dia might not change the RF performance much. But you might want to contact your PCB manufacturer if he can build 5mil dia blind vias reliably.
    Vivek
  • In reply to Vivek Dham:
    Hi Vivek,
    Thanks for your reply!
    What factors should be considered, so, the 5mil blind via is build reliable ?
    Michael Su
  • In reply to Michael Su:
    Hello MIchael,
    That is right, you need to check the manufacturability of these vias with you PCB vendor.
    Vivek
    Hi Vivek,
    I mean what manufacturability should be considered, so the 5-mil blind via will be built reliably
    Michael Su
    Hello Michael,
    You need to check with the manufacturer if they can drill a 5mil blind via. Smaller via size needs better precision equipments and not all manufacturers could do it. Am just curious why do you want to reduce the via size? In general people prefer bigger vias since they cost lesser.
    Vivek
    Hi Vivek,
    Michael Su
