  • TI Thinks Resolved
IWR1642: How do I use the IWR1642 with 2 RX and 1Tx
Expert 1240 points
Part Number: IWR1642
How do I use the IWR1642 with 2 RX and 1Tx. When I tried to change in the demo gui it says configuration error while sending the config file.
As said in the tuto, the sensor is power cycled before changing the config.
Pls help me to doit in step by step manner.
  • Hi Karthik,
    What did you change? Would you mind posting your GUI screenshot or chirp config used? We'll need more information in order to assist you.
    Cheers,
    Akash
  • In reply to Akash Gondalia:
     Hi Akash,
    I select 1Tx, 2 RX mode of operation. It tells to reboot the device. I will reset or power off te divice again I will open the visualizer change the mode(default antenna config 4Rx,2 Tx) to 1Tx 2 Rx, send the config file and will get the error in the configuration.
    Pls tell me the procedure to change the antenna config ans send the config using visualizer
  • In reply to karthik s60:
    Hi Karthik,
    Would you be able to post a full screenshot of the visualizer, including the console that includes the "SensorStart" command?
    Cheers,
    Akash
