Part Number: OPT8241-CDK-EVM
Hi, TI
Base on TI's schematic(OPT8241/9221) and BOM information , we build a new PCBA
The EEPROM Programmer stage is finished and the result is "EEPROM read back complete" and "Data verified successfully"
Currently, we remove emitter board and check receiver board (OPT8241/9221) board function first
The log shows these information:
INFO: ParameterDMLParser: Found register map with name 'OPT9221' (vPG1P0)
INFO: MainConfigurationFile: Reading from local copy of hardware configuration data
INFO: Data2DCodec: Original number of 8-bit offsets = 540
INFO: Data2DCodec: Number of invalid pixels in original data = 0
INFO: Data2DCodec: Current number of 8-bit offsets = 540
ERROR: DepthCamera: Could not set the camera profile to '79'
ERROR: DepthCamera:Could not get value for parameter TintinCDKCamera(0::0451:9105::10980011099927).vco_freq1
ERROR: DepthCamera: Failed to update value for parameter 'mod_freq1'
ERROR: DepthCamera:Could not get value for parameter TintinCDKCamera(0::0451:9105::10980011099927).vco_freq2
ERROR: DepthCamera: Failed to update value for parameter 'mod_freq2'
ERROR: DepthCamera: Failed to update value for parameter 'sysclk_in_freq'
ERROR: DepthCamera: Failed to update value for parameter 'quad_cnt_max'
ERROR: DepthCamera: Failed to update value for parameter 'pixel_data_size'
ERROR: DepthCamera: Failed to update value for parameter 'output_mode'
ERROR: DepthCamera: Failed to update value for parameter 'vco_freq2'
ERROR: DepthCamera: Failed to update value for parameter 'vco_freq1'
ERROR: CameraSystem: Could not refresh parameters for TintinCDKCamera(0::0451:9105::10980011099927).
ERROR: DepthCamera:Could not get value for parameter TintinCDKCamera(0::0451:9105::10980011099927).vco_freq1Traceback (most recent call last):
File "D:\voxelviewerbitbucket\voxelviewer-devel\build\VoxelViewer\out00-PYZ.pyz\PyVoxelViewer.docks.FrequentlyUsedParametersDockWidget", line 93, in updateView
File "D:\voxelviewerbitbucket\voxelviewer-devel\build\VoxelViewer\out00-PYZ.pyz\PyVoxelViewer.docks.FrequentlyUsedParametersDockWidget", line 46, in showParam
File "D:\voxelviewerbitbucket\voxelviewer-devel\build\VoxelViewer\out00-PYZ.pyz\PyVoxelViewer.views.ParameterHandlerROI", line 127, in __init__
File "D:\voxelviewerbitbucket\voxelviewer-devel\build\VoxelViewer\out00-PYZ.pyz\PyVoxelViewer.views.ParameterHandlerROI", line 259, in init
File "D:\voxelviewerbitbucket\voxelviewer-devel\build\VoxelViewer\out00-PYZ.pyz\PyVoxelViewer.views.XYSpinBox", line 35, in setRange
OverflowError
ERROR: ToFCameraBase: Could not get current frame rate
INFO: ToFCameraBase: Starting with 355x355@0fps
ERROR: TintinCDKCamera: Could not get current frame rate
The Voxel Viewer (V0.9.10) shows many error information.
Can you tell me how to solve these issues?
BR
Antonio
