Other Parts Discussed in Thread: AWR1443
I'm a beginner of in this area. I recently got the DCA1000 board. I followed the steps in "DCA1000EVM Quick Start Guide", but I got the following at the output:
GM: Constructor
GM: Wed Dec 19 17:27:54 2018
RSTD.Transmit("/Settings")
[17:27:54]
[17:27:54] ### Running Startup script: "D:\mmwave_studio_01_00_00_00\mmWaveStudio\Scripts\Startup.lua" ###
[17:27:54] RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
[17:27:54] RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
[17:27:54] Scripter ignored: Attempt to UnBuild() again or before Build.
[17:27:54] RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "D:\\mmwave_studio_01_00_00_00\\mmWaveStudio\\Clients\\\\LabClient.dll")
[17:27:54] RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
[17:27:55] RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
[17:27:55] RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
[17:27:55] RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
[17:27:55] RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
[17:27:55] RSTD.SetVar ("/Settings/AL Client/AL Dll" , "D:\\mmwave_studio_01_00_00_00\\mmWaveStudio\\RunTime\\SAL.dll")
[17:27:55] RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
[17:27:55] RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
[17:27:55] RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
[17:27:55] RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
[17:27:55] RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
[17:27:55] RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
[17:27:55] RSTD.Transmit("/")
[17:27:55] RSTD.SaveSettings(): Settings saved to "C:\Users\HP\AppData\Roaming\RSTD\config.xml"
[17:27:55] RSTD.Build()
[17:27:55] RSTD.AL_Build()
[17:27:55] RSTD.AL_LoadXml()
[17:27:55] RSTD.AL_Init()
[17:27:55] RSTD.Clients_Build()
[17:27:55] GM: Init
[17:27:55] GM: Loaded 'D:\mmwave_studio_01_00_00_00\mmWaveStudio\Clients\\LabClient.dll'
[17:27:55] GM: 1 Guest (s) init
[17:27:55] GM: 1 Module(s) init
[17:27:55] GM: 2 Tab (s) init
[17:27:55] RSTD.Client_LoadXml()
[17:27:55] [RadarAPI]: Starting Matlab Engine..
[17:28:16] [RadarAPI]: Matlab Engine Started!
[17:28:21] [RadarAPI]: ar1.LoadSettings('C:\Users\HP\AppData\Roaming\RSTD\ar1gui.ini')
[17:28:21] TESTING = false
[17:28:21]
[17:28:21] ***Script completed successfully.***
[17:28:26] [RadarAPI]: Opening Gpio Control Port()
[17:28:26] [RadarAPI]: Status: Passed
[17:28:27] [RadarAPI]: Opening Board Control Port()
[17:28:27] [RadarAPI]: Status: Passed
[17:28:28] [RadarAPI]: ar1.FullReset()
[17:28:28] [RadarAPI]: Status: Passed
[17:28:29] [RadarAPI]: Closing Board Control Port()
[17:28:29] [RadarAPI]: Status: Passed
[17:28:29] [RadarAPI]: Closing Gpio Control Port()
[17:28:29] [RadarAPI]: ar1.SOPControl(2)
[17:28:31] [RadarAPI]: ar1.Connect(3,921600,1000)
[17:28:34] [RadarAPI]: Warning: Connected with baudrate 115200
[17:28:35] [RadarAPI]: Warning: Disconnected existing BaudRate
[17:28:35] [RadarAPI]: Warning: Trying to connect with baudrate 921600
[17:28:36] [RadarAPI]: ar1.Calling_IsConnected()
[17:28:38] [RadarAPI]: ar1.SelectChipVersion("XWR1443")
[17:28:38] [RadarAPI]: Status: Passed
[17:28:39] [RadarAPI]: ar1.SelectChipVersion("XWR1443")
[17:28:39] [RadarAPI]: Status: Passed
[17:28:39] [RadarAPI]: ar1.SaveSettings('C:\Users\HP\AppData\Roaming\RSTD\ar1gui.ini')
[17:28:55] [RadarAPI]: ar1.DownloadBSSFw("D:\\mmwave_studio_01_00_00_00\\rf_eval_firmware\\radarss\\xwr12xx_xwr14xx_radarss_ES2.0.bin")
[17:28:56] [RadarAPI]: Downloading BSS ROM Legacy Binary..
[17:29:14] [RadarAPI]: ar1.DownloadMSSFw("D:\\mmwave_studio_01_00_00_00\\rf_eval_firmware\\masterss\\xwr12xx_xwr14xx_masterss_ES2.0.bin")
[17:29:15] [RadarAPI]: Downloading MSS Legacy Binary..
[17:29:22] MSS power up done async event received!
[17:29:22] [RadarAPI]: ar1.PowerOn(0, 1000, 0, 0)
[17:29:22] [RadarAPI]: Status: Passed
[17:29:22] [RadarAPI]: ar1.SaveSettings('C:\Users\HP\AppData\Roaming\RSTD\ar1gui.ini')
[17:29:24] [RadarAPI]: ar1.SelectCaptureDevice("DCA1000")
[17:29:24] [RadarAPI]: passed
[17:29:25] [RadarAPI]: StatusDCCard Event Registered
[17:29:25] [RadarAPI]: Status: Passed
[17:29:25] [RadarAPI]: ar1.CaptureCardConfig_EthInit("192.168.33.30", "192.168.33.180", "12:34:56:78:90:12", 4096, 4098)
[17:29:25] [RadarAPI]: SYSTEM_CONNECT_CMD_CODE Async event recieved(9)
[17:29:25] [RadarAPI]: ConnectRFDCCard Status: Passed
[17:29:25] [RadarAPI]: ReadRFDCCarFpgaVersion Status: Passed
[17:29:25] [RadarAPI]: READ_FPGA_VERSION_CMD_CODE event recieved(14)
[17:29:25] [RadarAPI]: ar1.CaptureCardConfig_Mode(1, 1, 1, 2, 3, 0)
[17:29:25] [RadarAPI]: CONFIG_FPGA_GEN_CMD_CODE Async event recieved(3)
[17:29:25] [RadarAPI]: ar1.CaptureCardConfig_PacketDelay(25)
[17:29:25] [RadarAPI]: CONFIG_PACKET_DATA_CMD_CODE Async event recieved(11)
[17:29:27] BSS power up done async event received!
[17:29:27] [RadarAPI]: ar1.RfEnable()
[17:29:27] [RadarAPI]: Status: Passed
[17:29:51] [RadarAPI]: ar1.ReadRegister(0xffffe210, 0, 31)
[17:29:51] [RadarAPI]: Value : 100001
[17:29:51] [RadarAPI]: ar1.ReadRegister(0xffffe218, 0, 31)
[17:29:51] [RadarAPI]: Value : 12
[17:29:51] [RadarAPI]: ar1.DownloadBSSFw("D:\\mmwave_studio_01_00_00_00\\mmWaveStudio\\Scripts\\..\\..\\rf_eval_firmware\\radarss\\xwr12xx_xwr14xx_radarss_ES2.0.bin")
[17:29:56] [RadarAPI]: Downloading BSS ROM Legacy Binary..
[17:30:01] [RadarAPI]: Warning: BSS firmware version Mismatch!
[17:30:02] BSS FW Download Success
[17:30:04] [RadarAPI]: ar1.DownloadMSSFw("D:\\mmwave_studio_01_00_00_00\\mmWaveStudio\\Scripts\\..\\..\\rf_eval_firmware\\masterss\\xwr12xx_xwr14xx_masterss_ES2.0.bin")
[17:37:20] MSS FW Download failure
I've been stuck with this step. I wonder why there is something wrong with the download of MSS FW and what should I do to solve this problem.
Elsie
