I am wondering about when measuring sensor frequency using the UI versus measuring it on a scope... I am not getting the same results, is this normal? I read in one part of the EVM guide that "Note that changing the value of the clock in the GUI is purely for calculations in the GUI, the actually clock frequency on the EVM will not change." Currently in the UI, I am seeing about 80kHz (with 3MHz external clock being selected) and when measuring by scope, about 3MHz at channel coil on the board. Also, can you refer me to where in the source code of UI the algorithm for calculating the sensor frequency is? Thank you.
Ali
