Hi folks,
Do you have 1443 antenna pattern measurement data? I have done some measurement and it does not match the simulation data provided in the data sheet .
Hi folks,
Hi Jitendra, Adrian,
We place a power meter at bore sight and put 1443 in CW transmission mode. The plate on which the 1443 is mounted is rotated with high precision at appropriate angles in azimuth and elevation. At each angle we record the power as read by power meter.
Does TI have any measured data which you can share? The data sheet or the EVM user guide contains only the simulation data.
