We are calculating the link buget to design the antenna gain, but we need to know what is the detectable SNR of the AWR1642 RX? could you provide it for us?
Michael Su
Michael Su
Hi Vivek,
Thanks for your reply,
one more qyestion,
Where is this SNR measured ? at input of the RX LNA? output of RX LNA? or at input of ADC ?
Michael Su
Hi Vivek,
The SNR is measured on ADC, so it undergoes the LNA gain and IF gain, right?
but for antenna design, the path the antenna engineer should consider is from TX output to RX input ( before LNA), right?
so I wonder that the RX SNR, 14 ~ 18dB, you siad before can be provided for antenna design?
Michael Su
Hello Michael,
The detection always happens on the SNR as seen from the ADC data of the RX channel. The SNR would depend on multiple factors like the TX o/p, antenna gain, distance of the object, RCS of the object. All these factors need to be considered while arriving at the antenna gain needed.
You can use the sensing estimator tool we provide to help you do some of these analyses (https://dev.ti.com/gallery/view/1792614/mmWaveSensingEstimator/ver/1.3.0/ )
Vivek
