  • Resolved
CCS/IWR1642BOOST: IWR1642
Intellectual 560 points
Part Number: IWR1642BOOST
We tested 1642Boost EVM and successfully had seen breathing rate and heart rate in the distance of 0.7 meter.
1) Now we would like to know how much it will show error rate comparing to FDA certified PSG.(EEG, EOG, ECG).
2) We would like to know how to calculate the accuracy over PSG.
3) Have you checked any comparison with Any FDA certified device ?
  • Hi Kisub Jung,
    I've referred your question to an mmWave Expert and someone should have an answer for you in the next few days.
    Cheers,
    Akash
  • In reply to Akash Gondalia:
    Kisub,
    Please keep in mind that this lab is used as a starting point for development. When testing with a pulse oximeter attached to the index finder, we find that the pulse oximeter readings and the output from the vital signs GUI match with some expected and slight variation.
    This lab is not intended to achieve the same rate as medical devices. The purpose of this lab is to show that mmWave sensors can be used to estimate vital signs for a driver in a car and provide information if it appears that the driver is incapacitated in some way.
    Kyle
