Other Parts Discussed in Thread: IWR1443, UNIFLASH, , MMWAVE-SDK
I am using level sensing demo software supplied from below link.
Hardware modification:
I have implemented below modification to IWR1443 eval kit.
Zero ohm added on R102, R9 and R164.
No HW modification had been done on MSP432 eval kit.
Software
1. I flashed below bin file to IWR1443 using Uniflash 5.0.0.2289
TI\tidcde2c\level_sense_demo\iwr1443\Debug\ level_sense_demo.bin
Output of successful flashing
[6/3/2019, 3:43:52 PM] [INFO] Cortex_R4_0: Initialization complete.
[6/3/2019, 3:43:52 PM] [INFO] Cortex_R4_0: Flashing process starting...
[6/3/2019, 3:43:52 PM] [INFO] Cortex_R4_0: Connecting to COM Port COM10...
[6/3/2019, 3:43:52 PM] [INFO] Cortex_R4_0: Reset connection to device
[6/3/2019, 3:43:52 PM] [INFO] Cortex_R4_0: Set break signal
[6/3/2019, 3:43:52 PM] [INFO] Cortex_R4_0: Connection to COM port succeeded. Flashing can proceed.
[6/3/2019, 3:43:52 PM] [INFO] Cortex_R4_0: Reading device version info...
[6/3/2019, 3:43:52 PM] [INFO] Cortex_R4_0: ** 1 files specified for flashing.
[6/3/2019, 3:43:52 PM] [INFO] Cortex_R4_0: Checking file /TI/tidcde2c/level_sense_demo/iwr1443/Debug/level_sense_demo.bin for correct header for IWR1443.
[6/3/2019, 3:43:52 PM] [INFO] Cortex_R4_0: IWR1443 device, fileType=META_IMAGE2 detected -> OK
[6/3/2019, 3:43:52 PM] [INFO] Cortex_R4_0: !! Files are valid for IWR1443.
[6/3/2019, 3:43:52 PM] [INFO] Cortex_R4_0: Format on download was specified. Formatting SFLASH storage...
[6/3/2019, 3:43:52 PM] [INFO] Cortex_R4_0: -->Erasing storage [SFLASH]
[6/3/2019, 3:43:52 PM] [INFO] Cortex_R4_0: -->Sending Erase command to device...
[6/3/2019, 3:44:05 PM] [SUCCESS] Cortex_R4_0: -->Erase storage completed successfully!
[6/3/2019, 3:44:05 PM] [INFO] Cortex_R4_0: Downloading [META_IMAGE2] size [92612]
[6/3/2019, 3:44:16 PM] [INFO] Cortex_R4_0: SUCCESS!! File type META_IMAGE2 downloaded successfully to SFLASH.
[6/3/2019, 3:44:16 PM] [INFO] Cortex_R4_0: Disconnecting from device on COM port COM10...
[6/3/2019, 3:44:16 PM] [INFO] Cortex_R4_0: Flashing instance clean-up initiated...
[6/3/2019, 3:44:16 PM] [INFO] Cortex_R4_0: Instance deinitialized!
[6/3/2019, 3:44:16 PM] [SUCCESS] Program Load completed successfully.
2.loaded below software on MSP432 EVAL kit using CCS9.0.1
TI\tidcde2c\level_sense_demo\msp432\Debug\ msp_level_sense_demo.out
3. After flashing I see below output on Putty from MSP432 eval kit
PGood Check Passed
MSP432: I2C Initialized!
MSP432: Wait for power good....
4. Now I remove SOP2 jumper from IWR1443 eval kit, Plug IWR1443 eval kit on top MSP432 eval kit, double checked connector mating to ensure boards are mated correctly.
5. Plug USB to MSP432 eval kit: I dont see any output on Putty/Teraterm, Supplied 5V power (Round black connector) to IWR1443 eval kit, still I dont get see any output on serial terminal.
Am I missing any HW modification on either IWR1443 or MSP432 eval kit?
OR software supplied in below link isnt functional ? Can you supply working binaries to rule it out from equation?
Mahendra
