Other Parts Discussed in Thread: AWR1642BOOST
Hello! I am trying to lower the transfer rate of the TLV protocol through the serial port from 921600 baud to 230400, because my end device does not support such a high speed. The code is successfully compiled and assembled, the chip is also successfully firmwared, but after configuring the chip and sending the "sensorStart" command, the device works for some time, and then the current consumption from the power source drops and the device stops transmitting data. After the reboot, everything repeats. Can anyone tell me what the problem is? The forum repeatedly mentions that you can change (including lower) the data transfer rate, but why then do I encounter such a problem? Thank you all for your attention!
