  • TI Thinks Resolved
IWR6843ISK: Removing ghost objects detection
Intellectual 290 points
Part Number: IWR6843ISK
I am using IWR6843ISK and MMWAVEICBOOST with sdk_03_02_00_04.
There are always ghost detected points next to the radar in the mmWave Demo Visualizer.
I know that it come from antenna coupling and that it is possible to remove that points with the command calibDcRangeSig. But I don't understand how to use that command and what the parameters correspond to.
Can you help me to understand how to remove that ghost detected points by using this command ? I have already tried to use it but it doesn't work.
Thank you,
Mathieu
  • Hi Mathieu,
    The calibDcRangeSig eliminates certain objects detected initially from a number of range bins close to the sensor. All of these parameters are configurable and defined in the mmWave-SDK User Guide on page 28.
    Cheers,
    Akash
  • In reply to Akash Gondalia:
    Thank you for your help but I already know all this informations.
    mmw_sdk User Guide is not clear for me and I don't understand what are <negativeBinIdx> and <positiveBinIdx>. What is a Bin ?
    Mathieu
  • In reply to Mathieu Delaveau:
    I still do not understand how to use the command.
    Can you help me please ?
    Mathieu
    Hi Mathieu,
    Range bins are specific intervals in the range domain where the sensor detects objects. The function is used to remove a specified number of bins that are closest to the sensor.
    For more information on mmWave Theory, I'd recommend looking in to the mmWave Training Series.
    Cheers,
    Akash
