  • TI Thinks Resolved
CCS/AWR1843BOOST: The selection of process noise covariance matrix Q
Expert 1690 points
Part Number: AWR1843BOOST
  In the MRR demo, there is a process noise covariance matrix Q  for kalman filtering algorithm. In the demo, the matrix is defined as follows:
QvecList[0]=halfatsq_x * halfatsq_x;
QvecList[1]=halfatsq_y * halfatsq_y;
QvecList[2]=at_x * at_x;
QvecList[3]=at_y * at_y;
 in the above array,halfatsq_x=1/2*ax*t^2,halfatsq_y=1/2*ay*t^2,at_x=ax*t,at_y=ay*t.
According to non-homogeneous state equation knowledge,there should be also other two elements, halfatsq_x*at_x and halfatsq_y*at_y for representing the process noise covariance matrix Q. Why  are the two elements discarded?
Rata
  • Guru 54575 points
    We are checking with algorithm developer and will get back to you early next week
    thank you
    Cesar
  • In reply to Cesar:
    Thanks, I am looking forward for your reply.
  • In reply to Rata Zhang:
    Hi Rata,
    We assume that there is no correlation between velocity and acceleration - the process noise matrix contains only diagonal elements.
    There are other approaches - where correlations are assumed between velocity, acceleration (in both x, and y), and they have better performance in certain use-cases .
    Anil
  • In reply to Anil Mani:
    Hi Anil,
        Thanks for your reply, if I add the other two elements to the the process noise covariance matrix Q,it is reasonable, is that right?
    Rata
    Hi Rata,
    I am not sure how the process noise of acceleration relates to velocity.
    Also, You would have to overhaul the kalman filter (KF), since the KF assumes a diagonal process noise matrix.
    Anil
