Other Parts Discussed in Thread: TDC1000, , TUSS4470, PGA460, TUSS4440, BOOSTXL-PGA460
We are currently using an off the shelf, ultrasonic sensor to measure the distance from water (in air) of a Hydrofoil vessel (MassaSonic FlatPack 160 that uses bistatic transducer topology at 160KHz )
the sensor gives us reasonable results, but is not flexible enough and very expensive.
our requirements :
2 cm - 150 cm detection range
high reliability and robustness to environmental conditions
Does TDC1000 fit for this purpose?
if so does TDC1000-C2000EVM will fit for quick proof of concept evaluation
if not do you have other suggested solution?
Assaf Friedman
CTO
