• Resolved
"tagkeyword" field search does not work
Expert 1330 points
The FAQ describes the "tagkeyword" search term field which can be used to search for specific tags, but it does not work.
Searching for "tagkeyword:MSP430FR5969" or "tagkeyword:MSP430-GCC-OPENSOURCE" return no results.
Jozef Lawrynowicz
MSP430-GCC Developer
www.mittosystems.com
  • Hi Jozef -
    I will look into this today and update you with our findings no later than tomorrow.
    Thanks for making us aware of the issue.
    John
    John Walker
    Online Support – Systems & Tools
    Texas Instruments, Inc.
  • In reply to John Walker:
    Hi again Jozef -
    This is related to the use of upper case letters in your search string. As a temporary workaround, while we chase down a fix, if you use lower case for the search terms, you will see results.
    We are still investigating the root cause. I'll report back tomorrow with an update.
    Thanks for your patience while we work through this.
    John Walker
    Thanks, lower case letters in the tag works for me.
    Jozef Lawrynowicz
  • In reply to Jozef_Lawrynowicz:
    Thanks Jozef - let me know if you see any additional issues with this, but lower case should work fine.
    John Walker
    Hello Jozef -
    Quick update here. I was hoping for a quick easy fix, but it was not in the cards. I've entered a bug on this and it should be addressed within the next 30 days. In the meantime, please continue to use lower case in any tagkeyword field searches.
    John
    John Walker
