Texas support
Other Parts Discussed in Thread: CD4070B, TLE2022, LM158, LM193, CD40106B, SN54LS14, CD4012B, CD4518B, CD4052B, CD4053B, TL074, SN54LS161A, TLC271, LP2951, LM117
In order to process a database of obsolescence, Safran Electronics and Defense wishes to know the status of the life cycle ("Active or Obsolete") and the estimated number of years until the end of life) for components below:
Désignation MATP Ref.Fab Fab. Status Sustainability EOL
TRANSISTOR BIPOLAIRE PNP 2N3244(PATS-SHR3067) TEXAS
LOGIQUE C/MOS B CD40163BF3A TEXAS
LOGIQUE HC SN54HC4049BJ TEXAS
TRANSISTOR BIPOLAIRE NPN 2N338 TEXAS
TRANSISTOR BIPOLAIRE NPN 2N3253 TEXAS
TRANS. PNP 2N3244 TEXAS
IC.LOG. CD4009UBF TEXAS
IC.LOG. CD4009UBF3A TEXAS
IC.LOG.MOS CD4025BFCDIL14 CD4025BF TEXAS
LOGIQUE C/MOS B CD4025BF/INV TEXAS
CIRCUIT INTEGRE CD 4025B F CD 4025B F CD4025BF/INV TEXAS
IC.LOG. CD4070B CDIP14 CD4070BF TEXAS
IC.LOG. CD4070B CDIP14 CD4070BF3A TEXAS
TRANS. TO92 3 BC182 TEXAS
IC.CMS TLE2022 DUAL AMPLI OP. CDIL8 TLE2022BMJGB TEXAS
DIODE ZENER 1N2970B TEXAS
DIODE ZENER 1N2991B TEXAS
IC. LM158 AMP.OP. 1 MHZ TO99 LM158AH/NOPB TEXAS
COMPARATEUR DE TENSION LM193H TEXAS
IC.LM193 DUAL COMPARATEUR TO99 LM193H/NOPB TEXAS
LOGIQUE C/MOS CD40106B CDIP14 CD40106BF3A TEXAS
IC.LOG. 40106B DIL14 CD40106BF TEXAS
IC.LOG. CD40106BF/3A/INV1 TEXAS
IC.LOG. 40106B DIL14 CD40106BF/INV2 TEXAS
IC.LOG. SN54LS14 CDIL14 SN54LS14J TEXAS
LOGIQUE TTL/LS SN54LS365AJ TEXAS
IC.LOG.SN54LS393J TEXAS SN54LS393J TEXAS
IC.LOG. CD4012BF DIP14 CD4012BF TEXAS
IC.LOG. CD4012B CDIP14 CD4012BF3A TEXAS
IC.LOG.4021B CDIL16 CD4021BF TEXAS
LOGIQUE C/MOS B CD4502BF3A TEXAS
IC.LOG. CD4518B CDIL16 CD4518BF TEXAS
IC.LOG.CD4518B CDIL16 CD4518BF3A TEXAS
DIODE INFRAROUGE TIL 23           TEXAS TIL23 TEXAS
TRANSISTOR BIPOLAIRE NPN 2N720A TEXAS
TRANSISTOR BIPOLAIRE NPN 2N720A1 TEXAS
PHOTO-TRANSISTOR LS600 TEXAS
*F2 TRANSISTOR TEXAS REF.2N930 2N930 TEXAS
IC.CMS LM101 AMP.OP.FP10 LM101AW/883 TEXAS
IC.ANALOG.52709 DIL14 SN52709J TEXAS
AMPLIFICATEUR OPERATIONNEL µA741MJ TEXAS
LOGIQUE TTL SN54193J TEXAS
IC.LOG.SN5400J SN5400J           TEXAS SN5400J TEXAS
TRANSISTOR BIPOLAIRE NPN 2N2605(PATS-SHR3065) TEXAS
TRANSISTOR BIPOLAIRE NPN 2N3246 TEXAS
PHOTOTRANSISTOR TIL604 TIL604 TIL604 TEXAS
AMPLIFICATEUR OPERATIONNEL SN52709AL TEXAS
AMPLIFICATEUR OPERATIONNEL SN52709AL/INV TEXAS
IC.LOG.54HC14 CDIL14 CD54HC14F CD54HC14F TEXAS
IC.LOG 54HC14 6X INVERT.SCHMITT. CDIL14 SN54HC14J TEXAS
IC.LOG.54HC14 CDIL14 BDE CD54HC14F/INV TEXAS
IC.LOG. SN54HC08J CDIL14 SN54HC08J TEXAS
IC.LOG 54HC123 2X MONOSTABLE CECC CDIL16 SN54HC123JYB TEXAS
IC.LOG CD54HC123F3A 2X MONOSTABLE CDIL16 CD54HC123F3A/5962-8684701EA TEXAS
IC.LOG.MOS CD54HC123F           CDIL16 CD54HC123F TEXAS
IC.LOG. CD54HC123F 2X MONOSTABLE CDIL16 CD54HC123F/INV TEXAS
LOGIQUE HC/MOS SN54HC138J TEXAS
IC.LOG. CMOS 54HC257 DIL16 SN54HC257J TEXAS
IC.LOG. CD4098BF3A TEXAS
IC.LOG. 14528B/4098B DIL16 CD4098BF TEXAS
IC.LOG. CD4517BF3A TEXAS
LOGIQUE C/MOS B CD4015BF3A TEXAS
IC.LOG CD4052B CDIL16 CD4052BF TEXAS
IC.LOG CD4052B CDIL16 CD4052BF3A TEXAS
IC.LOG.MOS CD4053B CDIL16 CD4053BF TEXAS
IC.LOG.MOS CD4001BF CDIP14 CD4001BF TEXAS
IC.LOG. 5962-9055701EA TEXAS
IC.LOG. CD14538BF TEXAS
IC.CMS MUTIVIB.MONOS.CMOS 15V CDIP16 CD14538BF3A TEXAS
IC.LOG. CD4017BF CDIL16 CD4017BF TEXAS
IC.LOG. CD4017BFA3 CDIL16 CD4017BF3A TEXAS
LOGIQUE C/MOS B CD4536BF3A TEXAS
IC.LOG. DIL14 CD4072BF3A TEXAS
IC.LOG. 4072B DIL14 CD4072BF TEXAS
IC.AMP. TL074 4X AMPLI.OP. CDIL14 TL074MJ TEXAS
IC.LOG.SN5410J SN5410J           TEXAS SN5410J TEXAS
IC.LOG.SN5432J SN5432J           TEXAS SN5432J TEXAS
IC.LOG.SN5437J SN5437J SN5437J TEXAS
LOGIQUE TTL SN54368J TEXAS
IC.LOG.SN54155J   TEXAS SN54155J TEXAS
LOGIQUE TTL SN5486AJ TEXAS
IC.LOG.SN54123J SN54123J         TEXAS SN54123J TEXAS
LOGIQUE TTL SNJ54123J TEXAS
IC.LOG.SN54157J   TEXAS SN54157J TEXAS
LOGIQUE TTL SN54166J TEXAS
IC.LOG.SN54174J   TEXAS SN54174J TEXAS
IC.LOG.SN54175J   TEXAS SN54175J TEXAS
IC.LOG.SN5474J SN5474J SN5474J TEXAS
IC.LOG.SN5404J SN5404J           TEXAS SN5404J TEXAS
LOGIQUE TTL SN54393J TEXAS
IC.LOG.SN54LS00J SN54LS00J TEXAS
IC.LOG.SN54LS04J SN54LS04J TEXAS
IC.LOG.SN54LS10J TEXAS SN54LS10J TEXAS
IC.LOG.54LS74A CDIL14 SN54LS74AJ SN54LS74AJ TEXAS
IC.LOG SN54LS74AJ   DUAL D       CDIL14 SN54LS74AJ/INV2 TEXAS
IC.LOG. 54LS85 DIL16 SN54LS85J TEXAS
IC.LOG.SN54LS123J SN54LS123J       TEXA SN54LS123J TEXAS
IC.LOG.SN54LS153J 5V CDIP-1 SN54LS153J TEXAS
LOGIQUE TTL/LS SN54LS157AJ TEXAS
LOGIQUE TTL/LS SN54LS161J TEXAS
IC.LOG. SN54LS161A CDIL16 SN54LS161AJ TEXAS
IC.LOG.54LS163A CDIL16 SN54LS163AJ SN54LS163AJ TEXAS
LOGIQUE TTL/LS SN54LS189J TEXAS
IC.LOG. 54LS221 DIL16 SN54LS221J TEXAS
IC.LOG. 54LS221 DIL16 SN54LS221J/INV TEXAS
IC.LOG.SN54LS670J SN54LS670J       TEXA SN54LS670J TEXAS
IC.LOG. CD4040BF CDIL16 CD4040BF TEXAS
IC.CMS TLC271 AMP.OP.SO8 TLC271ID TLC271ID TEXAS
IC.CMS TLC271 AMP.OP.SO8 TLC271IDG4 TEXAS
IC.CMS TLC271 AMP.OP.4-16V SOIC8 13" TLC271IDR TEXAS
IC.REG.CMS LP2951 AJUST.2,3V/30V SO8 13" LP2951CMX/NOPB TEXAS
IC.CMS COMP.TENSION DOUBLE 3-16V SO8 13" TLC3702IDR TEXAS
IC.CMS COMP.TENSION DOUBLE 3-16V SO8 13" TLC3702IDRG4 TEXAS
IC.LM117.REG.LINEAIRE 4,2V/40V TO3
LM117K STEEL TEXAS
