  • Resolved
[FAQ] How do I ask a question on E2E?
Here, you will learn how to complete the thread creation form to post a question on E2E after clicking "Ask a new question".
Note: We recommend always searching E2E prior to posting a new question.  E2E already has hundreds of thousands of threads with existing answers.  This is often the fastest way to solve your problem.
  • Part number
    • Include a device or reference design in the part number field.
    • When you start typing a part number, a drop down list will appear. You can continue typing and then select the appropriate choice.
    • If you don't have a part number, check the "I don't have a part number" box.
    • Part numbers can include:
      • ICs
      • EVMs
      • Software development tools
      • TI Designs (ex. TIDAx, PMPx)
    • If you are looking for a similar or “better than” device recommendation, enter the part number for the reference device.
    • If your question applies to an entire family of devices, choose a device from that family.
    • Create a separate thread for each problem you are having.
    Is your issue with one of these development tools/software?
    • Open the drop down under "Is your issue with one of these development tools/software?"
    • Only select a Development Tool/Software if your issue is with that Tool or Software.
    • Do NOT select a Development Tool/Software to just indicate what you are using.
    • If none of the options in the drop down relate to a Tool/Software, select "My issue is not related to any of the below."
    Select a forum
    • The forum selection will pre-populate based on the part number you entered.
    • If you don’t think the proper forum is being offered, post your issue anyways. We will ensure the proper team within TI sees it.
    E2E thread title
    • In the E2E thread title, include a short title with a phrase or several key words related to your issue.
      • Good example: “Output oscillates at 9kHz”
      • Bad example: “Part problem”
    • If you entered a Part Number or Development Tool/Software above, do not repeat it in the Thread Title field.  It will be automatically added as a prefix to your Thread Title.
    Tags
