TS5MP645:(TMUX646 Pin-to-pin upgrade supporting 6-GHz bandwidth available) What to do with unused pins for MIPI application?
Part Number: TS5MP645TMUX646
Other Parts Discussed in Thread: TS5MP646
From email:
Team,
I will not use Data Lane 3 and Data Lane 4 on this device. What should I do with the remaining pins on the device?
  1. Leave floating?
  2. Connect to ground?
  3. Terminate by resistor? (If so, how??)
Sonia
  • Sonia,
    Please follow the design procedures stated in the TS5MP646 and TS5MP645 datasheet and connect unused pins to ground with a 50ohm resistor to match that transmission line impedance and reduce reflections back into the device.
    Thank you,
    Adam
