Hello
Is the Enable pin of the Mux506 pulled down internally?
I know there are some products on the datasheet that other muxes are internally pulled down to a resistance of about 6M ohms.
However, there is no mention in the datasheet for this product. Is it possible to check this part?
Additionally, Is it better for Mux ic to have a pull down resistor on the control / output pin in switching?
Are there any differences in the output signal characteristics of the Mux when using the pull down resistor and when not using it?
Please check it.
Thank you.
Best Regards.
From Anthony.
