E2E,
May I know if TS5A22364 can support 3Vrms output for headphone? Peak voltage will be 4.3V. Hence, p2p voltage is 9V. The output signal will pass through this TS5A22364 switch.
Thank you,
Adam
E2E,
Thank you,
Adam
Hi Adam,
TS5A22364 has a recommended signal path voltage range of 5.5V, so a peak-to-peak voltage of 9V is not recommended.
Thank you for your interest, I will send your request to our product definition team to add to our creative backlog.
Kate
Hi Kate,
Since peak-to-peak voltage of 9V is not recommended, for the same application (headphone output) to use as click and pop noise reduction, can we TS5A22364 as shunt switch for mute where IN1 & IN2 are connected together as /MUTE as shown on the typical operating circuit below? NC1 is INL and NC2 is INR.
Thanks.
Gim Song
Hi Gim Song,
You may use TS5A22364 in this application, as long as your system operates within the recommended operating conditions in the datasheet.
Kate
