TMUX6136: SEL1=Low selects S1B, right?
Part Number: TMUX6136
Other Parts Discussed in Thread: AM26LV32,
In the datasheet[1], there seems no description about which port, S1A or S1B, gets selected by the High/Low level of SEL1 (or S2A/S2B by SEL2).  Although the Figure 20 looks SEL=High selects SB, the actual behavior we confirmed is SEL=High selects SA[2].  That's correct, isn't it?
I found a similar misprint in the AM26LV32 datasheet[3].  See the top-right of the Figure 4; A and B should be swapped.
[1] SCDS397 - NOVEMBER 2018
[2] That forced us to slightly modify the prototype board.
[3] SLLS202G - MAY 1995 - REVISED OCTOBER 2017
  • Hi Katsumi,
    Regarding TMUX6136, please refer to the following table (1) from page 19 of the datasheet, confirming that SEL=1 connects SA to D. Thank you for pointing out the typo in Figure 20 (Transition-time measurement setup), we will update this accordingly.
    Regarding the misprint in AM26LV32 datasheet, please create a separate E2E post to confirm this with the team supporting this device.
    Thank you for bringing this to our attention!
    Kate
  • Hi Kate,
    Thank you for the quick reply.  Oops, this issue is absolutely due to my overlooking.  Or I should have made a question here.  Sorry for the noise anyway.
