Does SN74CBTLV3253 support in UART signaling MUX/DEMUX?
If SN74CBTLV3253 does not do this, can team recommend the devices?
Peter,
These posts will help you evaluate if the switch is appropriate for your signal standard.
What devices are you trying to connect UART signals?
Configuration: How many UART signals are you trying to multiplex? How many different places would you like the signal to route?
Bandwidth: What datarate or bandwidth is your UART signal?
Voltage range: What is the maximum and minimum voltage of your UART signal?
CBTLV family of devices have bandwidth ~200 MHz as seen in this app note selecting the right Texas instruments signal switch.
Let me know if you have further questions.
Adam
